This section shows how to obtain an online CA signed certificate, remove the expired certificate, renew the certificate, and install an offline subject certificate.
Use the following procedure as an example to obtain an online CA signed subject certificate that the application can use.
In the following commands, the variable WORD<1-45> refers to the name of the certificate authority and the variable WORD<1-80> refers to the certificate file name.
Use the following procedure as an example to install an offline CA certificate.
In the following commands, the variable WORD<1-80> refers to the certificate file name.
Use the following procedure as an example to configure the SSH server on the switch, and the SSH client Secure CRT for two factor authentication using X.509 V3 certificates.
The following certificates must be loaded on the SSH server and SSH client:
For the Secure CRT (SSH client):
subject certificate from the PIV card.
For the switch (SSH server):
CAC-server.pem - the subject certificate
ca.cert.pem - the root CA certificate
Self-signedTrustAnchorCertificate.cer - the root CA certificate that signed the intermediate certificate
RSA2048IssuingCACertificate.cer - the intermediate certificate signed by the previous root CA that signed the subject certificate.
Use the following steps as an example to configure the SSH server on the switch, the RADIUS Windows server, and the SSH client Secure CRT.
X.509 Authentication User Name Option Example
Use the following procedure as an example to configure user name authentication options using X.509 V3 certificates.
